Shortcut keys for tags override key usage when writting email
With version 10.3.1720 (b574c3b), I was able to define shortcut keys for tags:
This was so useful as I come from Postbox where I had this defined.
But when I start writing a new email, number keys 1, 2, 3 don’t work in the body of the email :slight_smile:
They work in the To, Cc, Bcc fields and Subject field.
Bug? Feature? :slight_smile:
Hi, I forwarded this report to our team so we can get it fixed, that definitely does not sound like intended behavior :sweat_smile:
Thank you Olivia.
Any updates perhaps on this topic?
We have been able to replicate this issue on Mac and are working on a fix. Unfortunately, I don’t have an ETA on when the service update will be ready to go out yet.
Any update regarding this issue?
Thank you and best regards,
Ales
Yes, this issue should be fixed in the update 10.3.2040.0
https://www.emclient.com/dist/v10.3.2040_Mac/setup.pkg
Thank you for your reply, I also confirm on my end the issue is resolved.
Best regard,
Ales
