I’m connecting eM Client to a shared calendar on Kerio Connect server. If I share the calendar as read-write it works without error. But if I share the calendar as read-only, I get errors every time eM Client synchronizes.
Errors are like this:
11:39:55 User2 [CalDAV] MailExceptions.OperationException: Sync of User2/ failed due to error: User2 (Not found)
Same setup with same problems here.Kerio Connect with eM client 6. Any progress on this bug? We’re testdriving eM Client and would like to switch over from Outlook, but need to be sure about all functionalities.
Hi, no, there is no universal solution, usually this is caused by Kerio itself. Anyway you can follow my original reply and we might be able to find some solution.
for this problem i used the obvious workaround and gave everyone sufficient permissions with regards to colleague’s calendars. A lot of other problems with eM/Kerio are in need of a more urgent solution.
Sven, that’s probably a Kerio problem, not eM Client problem. Are you using Kerio 8.2? This behavior was introduced in 8.2 and fixed in 8.2.1, at least for Apple client.
I will have to check, what is going on. In the meantime you can disable reminders for specific calendars by right-clicking on them and unchecking “Show reminders” in Properties.
