Shared Tags across home mac and mac book
I have emclient on my homemacmini - then when i work at the office I use my macbook - I cant seem to have the same tags on both even though i am accessingthem the same way - 365?
How can i set this up - I set them up on my home mac - but they are not recognised on my macbook??
I recently gave some background on how tags sync, or don’t sync. Maybe it will be of use:
Correct - i set them up on the home machine - they arent syncing with the mobile/macbook.
I’m on office 365?
It depends on what you mean by Office 365.
If the email is hosted through Microsoft 365 and setup as Exchange, the tags and server tags list will sync.
If the email is setup as IMAP, so Outlook.com, they won’t sync at all because it is not supported by the server.
its here - same on both machines - log in the same??
is there a setting I’m missing I’ve gogled and used CHATGPT but neither helpful
It’s Exchange, so it will have full sync (both tags and tag list) to other devices using eM Client also connecting as Exchange.
If it’s not, as you have a paid license, please open a support ticket with us (Menu: Help > Get VIP Support) and we can investigate further.
first - are there any settings i should check??
There are no settings for this.
If you tag items in the folders for the Exchange account, you will see the tags on those items on the other device.
If you create tags in the server tags list, not Local tags list, you will see the same server tag list on the other device.
server list tags - wheres that ??
Have you looked at the Documentation (F1)?
theres nothing
I have looked through them all and there is nowhere about the issue I have
in any of the 27 - can you point at the one
