A while back, any calendar folder color would be saved when set. Recently, I can still change the color for a specific calendar in an account, but… in a CalDav account with multiple users, the color for individual user folder is not being saved.
Example: I have an MS teams calendar. I can change the color and after a restart, the color is still there.
For our company, we have multiple users who’s calendars are visible. My own calendar is called ‘Calendar’. I can change the color for that one without issue. But if I change any of the shared user calendar colors, they do change initially but after a restart, they have reverted back.
The current colors aren’t great and several users get the same color. So this is really a great thing to get fixed. Thanks!
When eM Client synchronizes a CalDAV account, it reads the calendar-color tag from the server for every calendar folder.
If you change the color of a shared or third-party calendar, eM Client initially saves this color locally.
Upon the next restart or synchronization, eM Client requests the latest metadata from the CalDAV server.
Since the server continues to provide its own default color for the shared calendar (and you lack write permissions on the server to change the color permanently for everyone), the server value overwrites your local change in eM Client.
I would recommend creating fixed categories/labels (preferably directly on the server). Since you have multiple users in your setup and alternative software alongside eM Client might be in use, you should additionally secure this setup using standard Microsoft software combined with CalDAV Synchronizer.
