I am trying to help my neighbor set up eMClient so she can stop using the HughesNet web mail interface. She’s 92 and it drives her crazy. I use eMClient on my own computer at home, so I thought it would serve her well.
I have set it up to use POP3/SMTP on legacy ports 995/465. I had tried this on my own computer and it worked (through HughesNet). But on her computer, it isn’t working. She is using Avast as her antivirus and it is on Windows 10. It keeps rejecting the credentials, though I am positive they are correct. What am I doing wrong?
See the below post to disable Avast Inbound Mail scanning.
Note:- If the below post setting is not the same as your version of Avast, then suggest to go to the Avast Forum for support on that product. Avast WEBforum - Index.
