Hi Matthew, if you want to setup a Rule for a specific domain just use ‘@domain.com’ in your rule instead of complete email addresses, and you should be able to setup a rule for the whole domain.
You can also setup a category automatically using this Rule.
The Issue: The rule does not seem to trigger or catch the emails when they arrive. Am I formatting the wildcard incorrectly, or does the “with words in the subject” condition treat the asterisk (*) as a literal string rather than a wildcard operator?
Could you please advise on the correct syntax or approach to achieve this filtering in eM Client?
