Server side searc does not work
I’m using emclient 9 with 5 IMAP Accounts. It seems like server side search does not work - i always have to download all the mails, which would be a huge waste of space.
Is there a setting i’m missing or does v9 just not support server side IMAP search?
Thank you!
If you have the option ticked in the drop-down in the search box and you don’t get any results, then probably your server doesn’t support it, there may be some server issue, or there are no results in the folders and fields you are searching.
