server connection failure on start up
I have installed emclient on four user computers. Each experience an unusual number error messages stating unable to connect to the outlook.com server. This occurs immediately after starting emclient ( set to not start upon boot). This appears to be a bug at startup, because a Refresh does not cause the same issue, all synching completes.
eM Client user here.
You may want to read this thread and focus primarily on John A’s comments about Hotmail and Outlook setups in eM Client for Microsoft’s outlook.com servers:
https://forum.emclient.com/emclient/topics/sync-with-outlook-com
Thanks for you quick response. Have read through the responses recommended. Having the latest build of emclient 7 I find that the creation of a new account is automatic and protocols are set up for IMAP, SMTP, and Airsynch.  Synch works well when emclient is fully operational and testing with Refresh.
I emphasise that the problem only occurs immediately after emclient starts and then it is fine. It seems that there needs to be a synch delay to allow for emclient to settle down.
I’m using eM Client 6 Pro.  You should be able have synchronization off at startup.  In version 6, I have to go to Tools/Settings/General/General/Synchronization and uncheck Synchronize items at startup.  See here (don’t know if version 7 setting is in the same location):
Not sure this will solve your problem, but worth a try.
Thank you for the settings advice, I have missed that. Time will tell if that is the fix.
