We have two email accounts linked to our eMClient. Today we updated eMClient, and now both email addresses are showing the same inbox/sent messages. In other words, the data from email one is doublicated into the second email account, and I cannot find any of my sent or received messages for the second email address. I have tried refreshing, shutting down and restarting the computer. Any help is appreciated!
Gary,
Thank you that worked great! After doing so however, several of my contacts no longer automatically pop up when typing an email. Any idea on how to update that?
I did not specifically sync contacts, so I am not sure! If not, I would assume I lost that data by deleting the account? Thankfully I can search messages and find the person’s email. I just have to manually enter the contacts again.
With accounts like Gmail, eM Client will sync messages, as well as contacts and calendars. So maybe that was the same for you. In that instance, removing the account removes the data from eM Client, but it is not lost as it still exists on the server. You can login using the webmail interface for your email provider, and see if the contacts are there. If they are, then all you need to do is sync those contacts with eM Client.
Who is your email provider? Maybe I can help you with syncing the contacts again.
