SENT folder sort order
The SENT folder (within my email account) does not provide sorting by SENT addressee; it *does* provide sort by RECEIVED, but this makes no sense since all contents in this folder is from the same RECEIVED address. There are other sort options (Priority, Attachment, Icon, Subject, Received, Category, and Flag). Sort order by SENT TO should be provided for this folder.
Hi, you can adjust the columns the folder is using by right clicking the “Sorted by…” and select “Columns configuration”, in the available columns you should see the option “Sent” move it to “Show these columns” using the add button and move the field to the top (to make sure it’s displayed using the compact message list on the left).
Also remove the “Received” column to avoid issues using both options.
Hope this helps,
