A few days ago, basic email sent is stuck in the outbox. I hit refresh, but still there. Any suggestion on next step is appreciated
Could possibly be a resident background program interfering with sending, or could be an email attachment size issue, or could be a server sending outage issue or could be your smtp server settings might possibly be incorrect.
So first thing “if you haven’t already tried”, is to close eM Client and shutdown and reboot your computer and then reopen eM Client and drag / move the email back to your Drafts folder and reopen & try sending again.
If it still won’t send “and you don’t have an attachment with it larger than what your smtp server allows”, then if you have any eg: optionally installed antivirus programs or optionally installed firewall / security programs or vpns installed “other than what comes default with your OS”, then try completely disabling those to test.
If you have no optionally installed programs like that or you do but disabling them made no difference, then next I would “check with your smtp mail server technical support” via phone or website chat if they have any current smtp sending issues incase it’s a sending server outage.
If your smtp server technical support don’t have any current sending problems then the smtp server settings may possibly be incorrect. So go to “Menu / Accounts” and click your SMTP tab and update what your Server address, Server port & Security policy is so we can dblcheck if there is any obvious errors in your settings.
Also update what version of eM Client you have an if you have Windows or Mac & OS version.
