Hi
I have installed em Client 6 and used automatical setup.
When I create a new Email then the sender account is not filled into the “From” field and I can’t fill-in it manually neither.
Thanks for help.
René Morel
Hi René, what version of eM Client are you currently using?
Can you go to Tools > Accounts, and check if you have an SMTP tab under your account.
