Send To eM Client using File Explorer not working
When I right click on a file in File Explorer and select Send To > eM Client (eM Client program not running), the eM Client program will open to the inbox but doesn’t open a new message window with the selected file attached. Is this normal? My default Mail App is eM Client. Thanks,
viernes 25 septiembre 2020 :: 2114hrs (UTC +01:00)
Hi Gary…
I have two email clients installed - The Bat! & eM Client where EMC is my default.
I just tested right click… etc with both clients NOT running and it works with both.
I’m running Windows 10 Pro.
I suspect it is a system problem not an email client issue.
See the snips.
EMC shows more content probably because it is the default.
Russ
