Select multiple Messages - Ctrl/Shift
I see you can click the ‘select’ mode to allow selection of multiple emails. But I want to just be able to select them normally via ctrl and shift similar to outlook by highlighting them in the email list window. Is this not possible?
Yes. Just do it that way.
Standard methods apply. Select one message, then using CTRL select another etc.
The CTRL/SHIFT only works if I go into ‘select mode’. I just want to do it from the regular view without entering the select mode. Is this possible?
Also when sorted by say ‘subject’ select mode is buggy as it doesn’t allow you to expand / close the group views. The > or V is frozen in that mode.
  1. Close and uninstall eM Client, making sure NOT to delete the database folder when asked. That will ensure all your data and settings are there later.
  2. If it exists, delete the C:\Program Files (x86)\eM Client folder.
  3. Download and install the latest version from here: https://www.emclient.com/dist/latest/setup.msi
  4. Restart Windows and start eM Client.
Then try the selection again
Where is this please? “select mode” - I am unsure how to select multiple emails. I have renstalled the software - which seems like a ridiculous way to go!
Normally to select a specific selection of messages as @Gary already advised above, you “click on the first message”, and then “hold down the Ctrl key” and while holding then click on whatever other specific messages you want.
Or if you want a specific selection / group of messages and not specific ones, then “click on the first message”, and then “press the Shift key”, and while holding click the last message in the list you want which will select all of them in a row / group.
If that doesn’t work then you might have a eg: different keyboard setup in your OS.
