Once a month I used to use the Search function to go through my Inbox and identify groups of emails that should be moved out of the Inbox into a folder. I can no longer do this. Now, instead of MOVING the emails from the Inbox they are COPIED into a folder. This means that I now have to go through the Inbox one email at a time before I can MOVE them to a folder. Grrrr. Anyone else frustrated by this?
And the print option is no longer easy find but requires me go to into the Menu to access it.
And finally, has anyone found a way to spell check a whole email as we used to rather than correcting one word at a time?
Hello Jan,
the copying from Search result is not a bug but a function. Since we adapted the Gmail format you cannot move messages from Search (just as it is in Gmail webmail). Moving in this situation just Adds another label, but since the message is located in only one folder (All mail) it cannot know from where you want to remove it. You need to remove the label manually.
Print can be added to the Toolbar. Just right-click the toolbar, choose Customize and add the Print button.
Setting for Spellcheck is made in Menu>Tools>Settings>General>Spellchecker. To trigger this spellcheck manually in the Message window, try Menu>Tools>Use Automatic Spellcheck.
