Search Folders: "Sender NOT x"
I have a search folder “Work”, the filter is “from:[email protected]”.
Now I want to setup a second folder “Non-Work”, where everything shows up that was not sent from [email protected] boss.
Is that possible?
Hello Lukas, unfortunately this is not possible using a search folder, as you can only use ‘AND’ and ‘OR’ conditions in the search field instead of the needed ‘except’ condition - you can however setup a local or IMAP folder on your account and setup a rule to move your incoming messages received from your non-work contacts (by using the except option on a custom received messages rule) into a specified folder.
Thank you, that’s a good solution.
Lukas
Glad it works, please make sure to let us know if you come across any other issues or questions about the application, we’ll be happy to help.
