The inbox scrolls to the latest message if the sorting order is ascending
so the latest message is at the bottom.
If the sorting order is descending it does not scroll at all.
I would like to see the latest message at the top if the sorting order is descending.
The filter is set to “Descending” and “Received”.
But the inbox does not scroll at all.
The filter is set to “Descending” and “Received”.But the inbox does not scroll at all.
If it’s set to received then you might have something going on with your external mouse scroll button if you use and external mouse.
or you might have a trackpad scroll setting that might need adjusting if you use a laptop.
or you might have an older version of eM Client that might need updating.
Do you have Windows or Mac and what OS ?
Also what version of eM Client are you using ?
the inbox does not scroll to the latest message automatically.
Scrolling with the mouse works fine.
Windows 10
eM Client 10.4.4867 (a1d5549)
Sounds like you want the Inbox to automatically scroll to the top when new mail arrives.
It’s by design currently that it doesn’t automatically scroll to the top of the inbox when new mail arrives “so you don’t loose your place in the message list”.
If you do want eM Client to automatically scroll to the top of the message list when new mail arrives, then there is already a few different suggestions you can vote for via the Sleekplan page.
You can also currently press the “Home” key to go straight to the top of the Inbox as a shortcut.
Or if it’s a Mac laptop without a Home key, press “Fn+left” keys.
again: the inbox scrolls to the latest message if sorting order is ascending.
Why does it not scroll to the latest message if sorting order is descending ?
Everyone would expect this and every other mail client does that.
My eM Client on Pc and Mac V10.4 “does not automatically scroll to the latest Inbox message even if Ascending / Received order” with the same eM Client version.
Why does it not scroll to the latest message if sorting order is descending ?.
It has never automatically scrolled to the top of the inbox when new mail arrives with any version of eM Client that I aware of unless that’s changed recently due to as I said “is currently by design so you wont loose where you are up to in the message list”.
I personally would not like it to automatically scroll to the top of the Inbox. Not for everyone.
So you have to vote for that idea via then Sleekplan page which would be an option in Settings if that was implemented.
It should work and it works works for me normally. What OS do you have? What is your search column? Received? Can you make a video or at least shortcuts? That may help, as we are not able to reproduce it. Of course it scrollls to the newest message when you are at the end of the list and a new message is received.
Now I can’t reproduce it neither.
It’s currently working as expected.
No idea why.
I’ll get back to you as soon as it reoccurs.
Thanks for your attention.
I investigated the problem again.
Scrolling to the latest message works if eM Client is opened.
Scrolling does not work if eM Client is minimized.
Hi, please let us know the following:
- Are you scrolling all the way up?
- Have you reproduced this issue 100% of time?
If so, please send us a screen recording of the issue to [email protected] so we can analyze it further. Thank you!
Unfortunately, we were unable to reproduce the issue on our side. We will continue investigating this.
Update: We were able to reproduce the issue. Hopefully we will be able to find a solution soon.
Update 2: This issue has been fixed - please update to the newest released version from our Release history.
