When I have an email opened and it’s not maximized, it’s almost impossible to use the vertical scrollbar with a stylus.
I made a film and it turns out as follows:
When not maximized, a small portion (leftpart, 1/3 of the width) of the vertical scrollbar can be used to drag the scrollbar. The right part of the scrollbar (2/3) can be used to resize the window. This is NOT correct, because the dark part (the scroller) should be completely used for scrolling and the small white part to the right of the scroller must be used to resize.
When maximized, then the whole width of the scrollbar can be used to scroll.
So, is it possible to widen the vertical scrollbar or define the correct width for scrolling?
Lastly You can customize any Theme via the “Theme Editor” in eM Client via “Menu / Tools / Theme Editor” or via “Menu / Settings / Appearance / Themes / Theme Editor” at the very bottom.
