I tried to make the scrollbar wider and now it is gone.
You probably made it transparent in the theme editor. It is invisible but still there if you hover it.
Select the “UseSystemScrollbar” and avoid “white” while defining a color for “ScrollBarThumb” and “ScrollBarThumbHover”.
Thank you. I realized that I had diminished it when I made the text smaller. By hitting ctrl and -, I made the message font smaller and also, the slide bar narrow. I reversed it, ctrl and +, and the text is smaller and the scrollbar is bigger.
