Saving my settings crashes eM Client
This is yet another issue I’ve encountered with the latest version: Every time I save my program settings, the programs crashes badly. i.e., it hangs and doesn’t react to anything I do. I have to kill the program in the Task Manager. The next time I start the program, I get the usual error warning and database check. I have tried saving to different locations, but that does not help.
I really don’t want to have to reinstall the program yet another time with no guarantee that things will improve. I have never had so many issues as with the latest version.
sábado 27 diciembre 2025 :: 1452hrs (UTC +0100)
Hey @merinber
I do not completely understand all you say, English is not my first language.
But before I can help first I have questions.
1./ What OS do you have?
2./ What version of eMC and is it Free or Paid?
3./ When you say “every time I save my program settings”
4./ Is this Backup or something else?
5./ Do you use POP or IMAP or both?
6./ Is the crash immediate or during the process?
skybat
¡Buena suerte!
In reply to your questions:
Windows 11 Pro, latest version
I have the paid version, 10.4.4209.
This refers to the Save program settings button, which generates the file: settings.xml
I use only IMAP.
The settings.xml file is generated and then everything suddenly freezes, i.e. stops working.
I recently reported a similar issue trying to save mails as EML files. I reinstalled the program, and it the problem disappeared until today–now it is back. I have never had such crashes before.
Here is a screenshot from the event viewer:
domingo 28 diciembre 2025 :: 1349hrs (UTC +0100)
Hey @merinber
I do not know the items you select to save as xml so I selected
all as in image and then removed one at a time with saving each
time with and without encryption.
All procedures worked correctly until the last with only one item
selected and eMC froze, I also used Task Master to close.
Then after a system reboot the final item did export correctly.
So my suspicion is that there is possibly some sort of error in
eMC though perhaps my OS contributed to this.
In conclusion I suggest that you raise a ticket with eMC support
unless one of the moderators views this and can help.
About your EML export issue I previously reported to you that
I had exported with no issues.
The only other possibility I can think of might be PC capability
though this doubtful, I have two high spec laptops.
Secondary Laptop (English):
Samsung Galaxy Book3 Ultra
Intel® EVO Core™ i9-13900H Processor
(2.6 GHz up to 5.4 GHz 24 MB L3 Cache)
Windows 11 Pro 25H2
32GB DDr5 RAM
NVMe SSD 512GB (x2)
Wi-Fi 6E
Bluetooth 5.1
16"120Hz Dynamic AMOLED Display
NVIDIA® GeForce RTX™ 4070 Laptop GPU
Backlit, Black with Number Pad
Main Laptop (Spanish):
Lenovo ThinkPad P16 Gen 2
Windows 11 Pro 64 25H2 Spanish
13th Generation Intel® Core™ i9-13980HX Processor
(E-cores up to 4.00 GHz P-cores up to 5.60 GHz) - (Total cores 24)
64 GB DDR5-5600MHz - (4 x 16 GB)
1TB SSD M.2 2280 PCIe Gen4 Performance TLC Opal - (2 x 512GB)
16" WQUXGA (3840 x 2400), OLED, Anti-Reflection/Anti-Smudge, Dolby Vision™,
Touch, HDR 500 True Black, 100%DCI-P3, 400 nits, 60 Hz, Low Blue Light
NVIDIA® RTX™ 5000 Ada Generation Laptop GPU 16GB GDDR6
Wi-Fi 6E
Bluetooth 5.1
Integrated Mobile Broadband Fibocom L860-GL-16 4G LTE CAT16
Backlit, Grey with Number Pad - Spanish
How eMC is installed:
I edited setup.msi for a non-standard install with nothing on (C:)
(E:) Program Files →
eM Client →
#Data# … cs da de Dictionaries …etc →
#Attach# … Sub-folders by Type of File / Client Name / etc
#Backup# … Backup Files timed for 1900hrs daily (process modified by ourselves)
#Calendar# … All ICS files
#Themes# … Non standard Themes
eM Client … Database #1 (Main working)
… Database #2 (Holding Company)
… Database #3 (Legal UK)
… Database #4 (Legal Spain)
… Database #5 (Master that includes #1, #2, #3, & #4 - 87Gb)
Database #5 is on an external drive & duplicated in cloud.
skybat
¡Buena suerte!
