i imported from thunderbird and the rules imported but i notice that under scope some of the rules apply to my account and others apply to all accounts. is there a way to change this? was wondering if i can select just my account or all accounts?
Hi, you can change this by modifying the rule and using it for your email address only.
i have tried that and i dont see anywhere to do that i have gone through the whole wizard but nothing i can see says anything about scope or which accounts i want to use the rule with. and when i setup a new rule it just puts the scope in all accounts.
There’s an option when you’re setting up the rule “processed with account” and if you select this option, you can choose for which account the rule will be applied to.
Hope this helps,
