I am struggling to get a rule to work for topic emails from a forum. I am trying to move them to their own folder. When I run this it does not move anything, what am I doing wrong?
Although the summary shows ‘from’ I actually chose ‘Includes’.
EmClient 8.2.1659
Are you sure that “noreply=” is part of the FROM field?
What happens if you omit those characters?
Yes it is exactly as the image. I tried adding it without the noreply as a ‘contains’, still no joy
Are you using WINDOWS or MAC?
That is probably not the address the message was sent from.
Find the message in eM Client.
Right-click somewhere in the message body.
Choose View Mail Header.
What is the From: address?
Thanks both
Windows 10.
The Mail Header window contained a lot !
Under Sender I found: “[email protected]”
Pasted that into the Rule and ran it, nothing happened,
Dug a bit deeper and found a From line
“[email protected]”
This one worked !!!
Thanks for your help
