Yeah, I was afraid of that. There’s 100s of mails in the imap inbox so I can’t do that, it’d create chaos.
Best I can do is copy a mail to an empty folder then run it…
Well, you want that Rule to move those messages to a local folder. If you run it manually, that is what it will do if it works. If it doesn’t work, nothing will change.
But for normal use, the Rule will only apply to new unread messages as they arrive in the Inbox. Existing messages that have been previously read will not be affected by Rules automatically.
So, ran that test and the rule worked ok…
OK, so the argument in the Rule is correct.
Yes… It’s just not triggering for some reason…
And FWIW they arrived marked as unread. Definitely a bug I think.
