Rules do not run automatically on launch
I installed eM Client on a new computer. I imported my rules. They work fine if I run them manually, but they are not running when I first launch eM Client.
lunes 29 junio 2026 :: 1744hrs (UTC +0100)
Hey @robinsiebler
As far as I am aware Rules only work automatically when mail is first downloaded.
¡Buena suerte!
Sorry, that is what I meant. It downloads the new email and …nothing. If I manually run the rules, it gets moved.
[quote=“robinsiebler, post:3, topic:117253”]
[/quote]lunes 29 junio 2026 :: 2158hrs (UTC +0100)
Hey @robinsiebler
If Rules are not working, first check that they are enabled then ensure that
they are configured correctly.
It would be useful if you either post a screenshot and or detail a Rule configuration
¡Buena suerte!
Never mind. I figured out what rules where not working and fixed them.
Sorry for the bother.
Tuesday 30 June
Hi @robinsiebler
It would be great if you shared your solution for the benefit of all.
Bonne chance!
Lucy_C
Several rules had “process with account” checked. Not sure how that got checked, but I must have hit it accidentally when I edited every single rule to point to the correct folder to move the mail into. I’m not sure why I had to do that either!
