In general I follow the “Zero Inbox” strategy to handle my mails. To archive that, I tag mails and move them to different folders.
I have following workflow very often:
Tag a mail
Move it to a specific folder with the mouse
It would be great, if a rule can be started, after a tag is added to an mail to execute the movement automatically.
BTW: Moving it automatically if the email is incoming is not applicable, because I have to read the mail before I can decide with shall happen with the mail.
Rules only apply automatically to new messages as they arrive in your Inbox. Generally they won’t have a tag when they arrive, so Rules can’t be used to process this.
thank you for your quick reply. So if I undestand you correctly, you will provide a new feature “Quick Actions” which will be coming with version 10, what can automate this kind of workflow, right?
