I am inundated with junk mail and have tried to use domain blocking and deletion but it doesn’t seem to be working. Now I do get thousands (yea a lot) daily and they keep coming. I have many email addresses from several domains. My question is the ‘Rule’ or filter account specific or is it global. Does it apply across ALL email accounts? Is there a way to make it global? AND, just where are the blocked domains listed in case I want to reverse it?
I love the emClient and can be overwhelmed by the options.
Thanks,
Skip Stein
HJS Enterprises
My question is the ‘Rule’ or filter account specific or is it global. Does it apply across ALL email accounts.
As far as I know the rules including the blacklists apply across all accounts. If that’s not correct someone will update this thread.
Have you tried a “adding a custom rule” to block “with words found in the header” ? As in @Gary example in the following thread post.
If you have V10 the blacklist is via “Menu / Settings (Preferences) / Mail / Blacklist” & Whitelist and click “Manage Blacklist” at the bottom
If you have up to V9, “the blacklist will appear in Rules” where you “dblclick to open / manage it”.
