rode driehoek met uitroepteken
ik krijg een rode driehoek met een uitroepteken achter mijn mailbox, wat is het probleem en hoe los ik dit op?
Google translate: “I get a red triangle with an exclamation mark behind my mailbox, what is the problem and how do I fix it”?
It could be a problem connecting with your mail server. How often are you checking your email? How reliable is your Internet connection?
Thanks for your reply Tony
I check my email several time a day.
My Internet connection based on glasfiber is normally very stable.
The red triangle has disappeared now…
