revert to 6 or repair 7
Version 7 is slow on my win 7 i5 with 32 GB.  Often sit waiting for screen updates when I change folders.   My unread email folder is empty but the number 625 is displayed on the left side of the screen by the UNREAD folder.  Are these database quirks that I can repair?
If I can’t how do I revert?   Not a fan of 7 atm
Hello Elwood,
We’re sorry to hear that the upgrade didn’t go smoothly. Could you please try the following steps?
Turn Conversations off (Menu -> View -> Conversations -> Disable Conversations)
Turn eM Client off
Go to eM Client’s installation folder (something like C:\Program Files (x86)\eM Client) and run DbRepair.exe (not the DbRepair.exe.config). Wait until the database check is completed.
Turn eM Client on
Maurice
I have done so twice but clearly something is scrambled.  In my unread folder I have emails every few minutes until now (23:03 GMT -7)  The newest entry in the ALL INBOXES folder is 3 hours old.  I responded to a message more than 3 hours ago but that email is now only visible in sent items.  I’ve just answered another couple of emails and it seems once I reply to an email the original no longer appears in the in box.  I can only see it by looking in sent items.
I don’t want to re-enable conversation view.  I don’t like it in GMail and I like it even less in emClient
Merci pour votre attention
Hello Elwood,
Thank you for the update. We understand that you don’t want to use the Conversation view. Could I please ask for more details? Is the number of the Unread e-mails the same or does it change?
Do you mean that after you respond to an e-mail, it disappears from the Inbox and is visible only in Sent? Can you please post a screenshot of your Inbox before you reply to an e-mail and a screenshot of what it looks like after your reply to it? Do you have some rules set up (Menu ->Tools -> Rules)?
Maurice
