Ok, eM Client Pro, Win 7 SP1. System crashed, and did complete reinstall of Win 7 starting from partition and format.
I have a system backup of the eM Client files from user\xxx\appdata\roaming\emclient.
I have tried numerous variations on install/restore files, restore files then reinstall EMC, install older version of EMC etc etc.
eM Client does it’s ‘checking for corrupted database’ thing, finds no problems, asks for the password, then opens. The various email accounts appear to be there, and downloads begin. Then it blows up. Error details below. It will do this apparently over and over forever.
I really need to be able to recover the email database. Any help appreciated on WHY it won’t run with the restored data.
Thanks
eM Client (6.0.19849.0)Windows: Microsoft Windows NT 6.1.7601 Service Pack 1, Framework: 2.0.50727.5485
System.Data.SQLite.SQLiteException: SQL logic error or missing database
at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at MailClient.Storage.Data.SQLite.DbMailRepository.RemoveOids[ST](Object senderContext, String oidList, IEnumerable1 items) at MailClient.Storage.Data.SQLite.DbRepository
1.RemoveByItems[ST](Object senderContext, IEnumerable1 items) at MailClient.Storage.Data.SQLite.DbRepository
1.Remove[ST](Object senderContext, IEnumerable1 items) at MailClient.RepositoryExtensions.Remove[T,ST](IRepository
1 repository, IEnumerable1 items) at MailClient.Protocols.Common.ItemSynchronizeContext
2.RemoveItems(IEnumerable1 obsoleteItems) at MailClient.Protocols.Common.ItemSynchronizeContext
2.Synchronize[T](SynchronizationType synchronizationType, IEnumerable1 items, Func
2 getUniqueId, Func3 hasChanged, Func
2 isDeleted, Func2 convertItems, Action
2 updateItem)
at MailClient.Protocols.AirSync.AirSyncItemSynchronizer2.Synchronize(IItemSynchronizeContext
1 synchronizeContext, Folder folder, CancellationToken cancellationToken)
at MailClient.Protocols.Common.ItemSynchronizer2.\<\>c\_\_DisplayClass30.\<\>c\_\_DisplayClass35.<enqueuesynchronize>b__2c(WorkerStatus status, CancellationToken cancellationToken)<br> at MailClient.Protocols.AirSync.AirSyncGenericCommand.Execute(WorkerStatus status)<br> at MailClient.Commands.Command.Process(WorkerStatus status)<br> at MailClient.Commands.SynchronizationQueue.ThreadWorker(Object threadData)<br> at System.Threading.ThreadHelper.ThreadStart_Context(Object state)<br> at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)<br> at System.Threading.ThreadHelper.ThreadStart(Object obj)<br><br><br><report xmlns="<a href=" http:>" rel="nofollow" target="_blank">http://emclient.com/ns/report">;<br> <product><br> <name>eM Client</name><br> <version>6.0.19849.0</version><br> </product><br> <silent>false</silent><br> <environment><br> <osversion>Microsoft Windows NT 6.1.7601 Service Pack 1</osversion><br> <frameworkversion>2.0.50727.5485</frameworkversion><br> </environment><br> <exception><br> <type>System.Data.SQLite.SQLiteException</type><br> <message>SQL logic error or missing database<br>SQL logic error or missing database</message><br> <source>System.Data.SQLite</source><br> <stack><br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663598</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLite3</type><br> <name>Reset</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteStatement</type><br> <name>stmt</name><br> </parameter><br> </parameters><br> </method><br> <offset>83</offset><br> <nativeoffset>184</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663597</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLite3</type><br> <name>Step</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteStatement</type><br> <name>stmt</name><br> </parameter><br> </parameters><br> </method><br> <offset>3c</offset><br> <nativeoffset>d9</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663982</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteDataReader</type><br> <name>NextResult</name><br> <parameters></parameters><br> </method><br> <offset>12f</offset><br> <nativeoffset>14a</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663943</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteDataReader</type><br> <name>.ctor</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>cmd</name><br> </parameter><br> <parameter><br> <assembly>System.Data</assembly><br> <type>System.Data.CommandBehavior</type><br> <name>behave</name><br> </parameter><br> </parameters><br> </method><br> <offset>5d</offset><br> <nativeoffset>79</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663757</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>ExecuteReader</name><br> <parameters><br> <parameter><br> <assembly>System.Data</assembly><br> <type>System.Data.CommandBehavior</type><br> <name>behavior</name><br> </parameter><br> </parameters><br> </method><br> <offset>c</offset><br> <nativeoffset>26</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663760</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>ExecuteNonQuery</name><br> <parameters></parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>27</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100685414</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Data.SQLite.DbMailRepository</type><br> <name>RemoveOids</name><br> <genericarguments><br> <argument><br> <assembly>MailClient</assembly><br> <type></type><br> </argument><br> </genericarguments><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>senderContext</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.String</type><br> <name>oidList</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type></type><br> <name>items</name><br> </parameter><br> </parameters><br> </method><br> <offset>cb</offset><br> <nativeoffset>265</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100670053</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Data.SQLite.DbRepository
1
RemoveByItems
MailClient
mscorlib
System.Object
senderContext
mscorlib
items
151
3af
MailClient.exe
100670054
MailClient
MailClient.Storage.Data.SQLite.DbRepository1</type><br> <name>Remove</name><br> <genericarguments><br> <argument><br> <assembly>MailClient</assembly><br> <type></type><br> </argument><br> </genericarguments><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>senderContext</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type></type><br> <name>items</name><br> </parameter><br> </parameters><br> </method><br> <offset>1c</offset><br> <nativeoffset>a0</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100670133</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.RepositoryExtensions</type><br> <name>Remove</name><br> <genericarguments><br> <argument><br> <assembly>MailClient</assembly><br> <type></type><br> </argument><br> <argument><br> <assembly>MailClient</assembly><br> <type></type><br> </argument><br> </genericarguments><br> <parameters><br> <parameter><br> <assembly>MailClient</assembly><br> <type></type><br> <name>repository</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type></type><br> <name>items</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>69</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100667471</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Protocols.Common.ItemSynchronizeContext
2
RemoveItems
mscorlib
System.Collections.Generic.IEnumerable1[[System.Object, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]</type><br> <name>obsoleteItems</name><br> </parameter><br> </parameters><br> </method><br> <offset>ae</offset><br> <nativeoffset>2f8</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100667474</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Protocols.Common.ItemSynchronizeContext
2
Synchronize
MailClient
MailClient
MailClient.Protocols.Common.SynchronizationType
synchronizationType
mscorlib
items
LinqBridge
getUniqueId
LinqBridge
hasChanged
LinqBridge
isDeleted
LinqBridge
convertItems
LinqBridge
updateItem
31b
abd
MailClient.exe
100666635
MailClient
MailClient.Protocols.AirSync.AirSyncItemSynchronizer2</type><br> <name>Synchronize</name><br> <parameters><br> <parameter><br> <assembly>MailClient</assembly><br> <type></type><br> <name>synchronizeContext</name><br> </parameter><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Application.Folder</type><br> <name>folder</name><br> </parameter><br> <parameter><br> <assembly>MailClient</assembly><br> <type>System.Threading.CancellationToken</type><br> <name>cancellationToken</name><br> </parameter><br> </parameters><br> </method><br> <offset>443</offset><br> <nativeoffset>f07</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100697149</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Protocols.Common.ItemSynchronizer
2+<>c DisplayClass30+<>c DisplayClass35
<EnqueueSynchronize>b__2c
MailClient
MailClient.Commands.WorkerStatus
status
MailClient
cancellationToken
d9
1d6
MailClient.exe
100666701
MailClient
Execute
MailClient
status
5a
ba
MailClient.exe
100664002
MailClient
Process
MailClient
status
15
51
MailClient.exe
100664052
MailClient
ThreadWorker
mscorlib
System.Object
threadData
8c
109
mscorlib.dll
100668077
mscorlib
ThreadStart_Context
mscorlib
System.Object
state
3b
72c311
mscorlib.dll
100667884
mscorlib
Run
mscorlib
executionContext
mscorlib
System.Threading.ContextCallback
callback
mscorlib
System.Object
state
58
6e
mscorlib.dll
100668078
mscorlib
ThreadStart
mscorlib
System.Object
obj
f
49
0
MailClient.exe
C:\Program Files (x86)\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
6.0.19849.0
eM Client
eM Client
6.0.19849.0
False
False
False
False
False
Language Neutral
ntdll.dll
C:\Windows\SysWOW64\ntdll.dll
ntdll.dll
ntdll.dll.mui
6.1.7600.16385 (win7_rtm.090713-1255)
NT Layer DLL
Microsoft® Windows® Operating System
6.1.7600.16385
False
False
False
False
False
English (United States)
MSCOREE.DLL
C:\Windows\SYSTEM32\MSCOREE.DLL
mscoree.dll
mscoree.dll
4.0.40305.0 (Main.040305-0000)
Microsoft .NET Runtime Execution Engine
Microsoft® .NET Framework
4.0.40305.0
False
False
False
True
False
KERNEL32.dll
C:\Windows\syswow64\KERNEL32.dll
kernel32
kernel32
6.1.7601.18015 (win7sp1_gdr.121129-1432)
Windows NT BASE API Client DLL
6.1.7601.18015
False
False
False
False
False
KERNELBASE.dll
C:\Windows\syswow64\KERNELBASE.dll
Kernelbase
Kernelbase
6.1.7601.18015
False
False
False
False
False
ADVAPI32.dll
C:\Windows\syswow64\ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
Advanced Windows 32 Base API
6.1.7600.16385
False
False
False
False
False
msvcrt.dll
C:\Windows\syswow64\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.7601.17744 (win7sp1_gdr.111215-1535)
Windows NT CRT DLL
7.0.7601.17744
False
False
False
False
False
sechost.dll
C:\Windows\SysWOW64\sechost.dll
sechost.dll
sechost.dll.mui
Host for SCM/SDDL/LSA Lookup APIs
6.1.7600.16385
False
False
False
False
False
RPCRT4.dll
C:\Windows\syswow64\RPCRT4.dll
rpcrt4.dll
rpcrt4.dll.mui
Remote Procedure Call Runtime
6.1.7600.16385
False
False
False
False
False
SspiCli.dll
C:\Windows\syswow64\SspiCli.dll
security.dll
security.dll
6.1.7601.18637 (win7sp1_gdr.141013-1517)
Security Support Provider Interface
6.1.7601.18637
False
False
False
False
False
CRYPTBASE.dll
C:\Windows\syswow64\CRYPTBASE.dll
cryptbase.dll
cryptbase.dll
Base cryptographic API DLL
6.1.7600.16385
False
False
False
False
False
mscoreei.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
mscoreei.dll
mscoreei.dll
4.0.30319.18408 built by: FX451RTMGREL
4.0.30319.18408
False
False
False
True
False
SHLWAPI.dll
C:\Windows\syswow64\SHLWAPI.dll
SHLWAPI
SHLWAPI.DLL.MUI
Shell Light-weight Utility Library
6.1.7600.16385
False
False
False
False
False
GDI32.dll
C:\Windows\syswow64\GDI32.dll
gdi32
gdi32
6.1.7601.18577 (win7sp1_gdr.140822-1508)
GDI Client DLL
6.1.7601.18577
False
False
False
False
False
USER32.dll
C:\Windows\syswow64\USER32.dll
user32
user32
6.1.7601.17514 (win7sp1_rtm.101119-1850)
Multi-User Windows USER API Client DLL
6.1.7601.17514
False
False
False
False
False
LPK.dll
C:\Windows\syswow64\LPK.dll
LanguagePack
LanguagePack
6.1.7601.18177 (win7sp1_gdr.130605-1534)
Language Pack
6.1.7601.18177
False
False
False
False
False
USP10.dll
C:\Windows\syswow64\USP10.dll
Uniscribe
Uniscribe
1.0626.7601.18454 (win7sp1_gdr.140424-1533)
Uniscribe Unicode script processor
Microsoft® Uniscribe Unicode script processor
1.0626.7601.18454
False
False
False
False
False
IMM32.DLL
C:\Windows\system32\IMM32.DLL
imm32
imm32
Multi-User Windows IMM32 API Client DLL
6.1.7601.17514
False
False
False
False
False
MSCTF.dll
C:\Windows\syswow64\MSCTF.dll
MSCTF
MSCTF.DLL.MUI
MSCTF Server DLL
6.1.7600.16385
False
False
False
False
False
mscorwks.dll
C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
mscorwks.dll
mscorwks.dll
2.0.50727.5485 (Win7SP1GDR.050727-5400)
Microsoft .NET Runtime Common Language Runtime - WorkStation
2.0.50727.5485
False
False
False
False
False
MSVCR80.dll
C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4940_none_d08cc06a442b34fc\MSVCR80.dll
MSVCR80.DLL
MSVCR80.DLL
8.00.50727.4940
Microsoft® C Runtime Library
Microsoft® Visual Studio® 2005
8.00.50727.4940
False
False
False
False
False
shell32.dll
C:\Windows\syswow64\shell32.dll
SHELL32
SHELL32.DLL.MUI
Windows Shell Common Dll
6.1.7601.17514
False
False
False
False
