My contacts disappeared and were not backed up in Em Client. I back up my hard drive regularly. I’d like to identify and copy the file containing the contacts from the back up and then paste it into the Em Client application running on my computer. How can I do that? I don’t want to uninstall and install Em Client because I don’t want to lose my email. Would appreciate your help.
As your eM Client backup didn’t contain your contacts where it normally does, you would need to restore “the entire database” as you can’t normally restore just the contacts part of the database or you risk corrupting your entire current database.
So if you only have one backup and that didn’t have your contacts, then if you have a backup of either your computer user profile or computer complete image when you know the contacts were there, then first if you have a POP account go to “Menu / File / Export” and choose “Export emails to (.eml) and then select a folder on your eg: desktop or downloads etc to save that and export.
“Export to .eml documentation”
Also if you have any POP calendars, tasks etc that you need, export those as well to a folder via the same “Menu / File / Export”
“Export files documentation”
Then once everything you need is exported, then “close eM Client” and go to the following eM Client hidden database folder below and “rename it” to eg: eM Client-Old
(Hidden database folder Mac)
/Users/User Name/Library/Application Support/eM Client
Then “go to your computer user profile backup or complete image backup” and copy the eM Client hidden database folder into exactly the same Roaming or Application Support location.
Then finally reopen eM Client and your contacts should be there if they were there previously. Then for a POP account, import your exported emails, calendar, tasks etc via “Menu / File / Restore”
“Import .eml messages documentation”
“Import files documentation”
Lastly if your have a IMAP, Exchange, Graph, Office 365 or iCloud account then your Mail, Contacts, Calendar, Tasks etc would normally be all on the server end and no need to export anything.
So “if your contacts are all showing online ok but not in eM Client” then suggest to first make a new backup via “Menu / Backup”. You can see when the backup is complete in Show Operations via the dropdown on the right of Refresh.
Then once backed up, go to “Menu / Accounts” and remove and re-add your account and all your contacts should then come back into eM Client.
If however your contacts are not online and you have a IMAP, Exchange, Graph, Office 365 or iCloud account, then contact your mail server technical support to see if they can restore them
