Hi there,
I was wondering if it’s possible to automatically resize images when you attach them? Currently when they’re inserted (I believe via prnt screen and then ctrl + v) the size needs to be changed to original manually. Is there any way to change the settings so that when they’re added in, they’re automatically sized as original or large?
Thanks for your time!
