When using Postbox I used to filter my emails through “Mailwasher” which had a handy feature allowing spam to be reported directly to Spamcop www.spamcop.net
Can eMClient do something similar?
Can you screenshot “how you used to do that in Postbox” as an example in this thread.
Please note, this was done in “Mailwasher” before opening Postbox.
My query refers to doing the same thing in eM Client, and thus removing the requirement to use Mailwasher at all.
Having said that, I understand Mailwasher forwarded the complete raw data (all headers, routing information, internal links, etc) of the offending email(s) to a client specific email address. (Without adding it/them into the sent mail folder).
Mailwasher also had the ability to “bounce” the email back to the sender as “recipient unknown”, delete it from the inbox and add the sender’s email address to a blacklist all at the same time.
eM Client doesn’t currently control any external spam programs like that im aware of. So you would have to still do that in Mail Washer like you did before.
eM Client would probably need some sort of eg: plugin to do that, but eM Client doesn’t currently support external plugins.
You can certainly suggest that type of thing via the Sleekplan page.
