Réponses et discussions, archivage perdu
Bonjour,
J’ai remarqué un comportement assez pénible : lorsque j’archive un mail dans un dossier, si je fais répondre par la suite, la discussion est déplacée dans le dossier “Envoyés” eu lieu de rester là où elle a été archivée.
Est-ce un mauvais paramétrage ou un bug ?
Merci
I’ve noticed a rather annoying behavior: when I archive an email in a folder, if I then reply, the conversation is moved to the “Sent” folder instead of staying where it was archived.
Is this a setting error or a bug?
I suspect this happens because it’s an archive folder which are different than normal folders.
Does this also happen if you reply to a message in a conversation in a non archive folder ?
If it happens in non archive folders then there is a current Sleekplan suggestion you can vote for to keep the sent messages in same folder as original.
Hi @cyberzork , it is exactly the Sleekplan suggestion that you shared, i voted +1 !
Thanks
