Renaming a folder causes problems with the rules referring to it.
Let’ suppose I have a rule which moves my incoming mails into the “myfriend” folder when it is received from “[email protected]”. If I rename the folder from “myfriend” to “my_best_friend” then the rule will not work anymore.
In such cases emclient should warn me:
The folder to be renamed is referred to in the following rules:
Emc should also ask my choice:
- disable depending rules
- delete depending rules
- modifying depending rules properly
- cancel renaming folder
Thanks.
