how can I rename “Coworkers”??? or can i remove it ??
Jaap
Hi, what “coworkers” do you mean?
Jan
I mean de category “coworkers”, ther are many categorys but not all have the name that I want to give them.
I can rename them
Grtz
Jaap
main toolbar - Tools - Categories, there you can add and remove/rename your categories.
Jan
I am sorry, dut it dus’nt work, it comes back every time, when I remove it and start the program again it’s still there
Then just add new one and don’t use default “coworkers”, this does not works for you?
Jan
ofcorse…I can make a new one, but why can I not rename a catagory, or simply remove it? my contacts are now under “my contacts” why is it not possible to rename it in “mijn contacten” (Dutch)
grtz
Jaap
Because these are default categories and they can’t be renamed and altered.
You can create yours and these standard ones will not be used, but this is not problem for functionality.
Jan
OK…
thks a lot
grtz
Jaap
you are welcome.
Jan
