Reminder notification pop-up window customization
Hi all,
I would like to be able to customize the reminder notification pop-up window. I hit “dismiss all” several times instead of “dismis” and I have to manually check what was on “to do” list and what was solved. I would like to delete the dismiss all button completely. IS it possible?
Thanks
Unfortunately the Reminders window cannot be customized right now, but you can add your vote to the idea on our sleekplan here:
That way you will get notified when the idea is approved and/or implemented.
same here!
another possibility would be to have only short term dismiss for “Dismiss All” (max. 1 hour e.g.)
