The power goes down here sometimes. And it takes three hours or so for emclient to check for database corruption. Is there anything i can do to speed that up eg. creating subfolders etc?
The power goes down here sometimes. And it takes three hours or so for em client to check for database corruption.
If you do regular eM Client backups either automatically via “Menu / Settings (Preferences) / General / Backup” or manually via “Menu / Backup”, then you could alternatively, cancel the database repair and restore a recent backup via “Menu / File / Restore”.
Taking 3 hours to do a database repair is very unusual. That could mean you more than likely have a problem with your database anyway and probably need to look at creating a new database.
Ps I used to live in a property where the power used to go off alot, where to avoid computer programs corrupting when the house power dropped, i bought a UPS (uninterruptible power supply) and plugged the computer into that, which then was able to keep the computer going for around 15-20 mins. So allows you then to power the computer off normally to avoid corruptions.
Thanks. A UPS is on the shopping list since we started getting more cuts.
I guess my database is big because it’s taking me about an hour to do a backup as well - but I have quite a few other processes competing for HDD time. So regular backups aren’t really an option. There’s about 15 years of mail in there.
