I keep getting this error message. The full text is: "“the following occurred when processing an iMIP message: One of the identified items was in an invalid format.” I press the OK button and it goes away but soon pops up again when I try to delete an email or read a messsage. Any ideas?
I have the same problem too, it’s so annoying.
OS: Windows 7 Pro 64 Bit
emClient version: 8.0.2951 (e2fe9f0)
Hi everyone,
please try this newer version and see if the same issue still happens: https://www.emclient.com/dist/v8.0.3283/setup.msi
If so, can you provide more details on which accounts this happens with? Are they set up as POP, IMAP or EWS?
Thank you for your cooperation.
