I set up a repeating event for the 3rd Monday of every month. Later, not sure under what circumstances, that event shows every Monday. If I open the event, I see this:
Note the highlighted part: 0th Monday.
This is consistent, every monthly repeating event I have created since upgrading to v11.
For this particular event, the final occurrence was moved from December 21st to December 14th. When I made that change, checking it was just for “This” occurrence, it added a complete series on 0th Monday again.
It seems to be fixed, but after I changed the one event that is out of the sequence, I stated getting this error:
[Microsoft Graph] Uploading item(s) to folder ‘[email protected]/Calendar’ failed due to the following error: Cannot resolve Microsoft Graph occurrence id for recurring event update.
Will this be fixed in a future beta release prior to the full public release, or is there something I can do to resolve the issue in the current beta version? I have to use 11 beta with Graph API support since Microsoft retired EWS October 1. I don’t think Graph is supported in em Client 10, right?
Hi @Keith_Collyer & @emsf,
Please try downloading the most recent version 11 via Menu>eM Client>Check for update. Then, run a repair on the affected account folder by right-clicking on the folder, clicking Properties, navigating to the Repair tab, clicking Repair, and clicking Ok.
This should fix the issue. Please let me know if not.
It may have fixed that issue, but I now have another which, from the Error dialogue, seems to be related. I get no updates from Microsoft Graph at all. Log sent via email. Deleting the “out of band” recurrent event seems to fix it, but that’s clearly not acceptable
