I had a hard drive fail, managed to recover with software the files in the hard drive, this happened after December 17 so I assume I had the latest version of the email client.
I installed it again, copied all the folders to the new client and the program crashes, this is the message I get: (I need to recover most emails but most important my contacts)
System.Data.SQLite.SQLiteException (0x80004005): file is encrypted or is not a database
at System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
at System.Data.SQLite.SQLiteCommand.BuildNextCommand()
at System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at System.Data.SQLite.SQLiteConnection.Open()
at MailClient.Storage.Data.DataStore.GetConnectionInternal(String relativeName)
at DbRepair.CorruptionChecker.CheckCorruption(RepairOptions repairOptions, CancellationToken token)
at DbRepair.CheckingProcess.Check(CancellationToken token)
Data:
SQLiteCommandText: PRAGMA synchronous=Normal
databaseFile: accounts.dat
you may have to install version 6 first and then upgrade to 7.
Did that didnt work
