Long story short… Laptop and HD fried without proper backup. Sent out HD for recovery and I now I have the contents of:
C:\Users\Leon\AppData\Roaming\eM Client
I downloaded and installed Version 6.0.24432 and was surprised to NOT find a similar directory. I am desperate to retrieve my contacts from the old database. I believe it was saved. I see some dat files which, when dumping in hex/ascii I can tell have the contacts I want.
It would be terrific if someone has an idea on how I might accomplish this. I don’t have the old client.
Hi Leon,
AppData is a hidden folder by default. If you paste the whole location into the File Explorer, you will access the new database.
Just copy the whole folder there and eM Client will load from the older database.
Now that I’ve done that, every time I reboot my PC and every time I try to access EM, it starts a database check on mail-fti.dat and then shuts down with an EM Client Application Error. I really like EM but it doesn’t seem to want to work for me!
The following is the text of the dump data:
eM Client (6.0.24432.0)Windows: Microsoft Windows NT 6.2.9200.0, Framework: 4.0.30319.34209
System.ArgumentOutOfRangeException: startIndex cannot be larger than length of string.
Parameter name: startIndex
at System.String.Substring(Int32 startIndex, Int32 length)
at MailClient.Imap.Synchronizer.GetSelectPath(ImapAccount account, Folder folder)
at MailClient.Imap.Synchronizer.AppendCommand.ExecuteInternal(WorkerStatus status)
at MailClient.Imap.Synchronizer.ImapCommand.Execute(WorkerStatus status)
at MailClient.Commands.SynchronizationQueue.ThreadWorker(Object threadData)
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ThreadHelper.ThreadStart(Object obj)
MailClient.exe C:\Program Files (x86)\eM Client\MailClient.exe MailClient.exe MailClient.exe 6.0.24432.0 eM Client eM Client 6.0.24432.0 False False False False False Language Neutral
ntdll.dll C:\windows\SYSTEM32\ntdll.dll ntdll.dll ntdll.dll.mui 6.3.9600.17031 (winblue_gdr.140221-1952) NT Layer DLL Microsoft® Windows® Operating System 6.3.9600.17031 False False False False False English (United States)
MSCOREE.DLL C:\windows\SYSTEM32\MSCOREE.DLL mscoree.dll mscoree.dll 6.3.9600.16384 (winblue_rtm.130821-1623) Microsoft .NET Runtime Execution Engine Microsoft® Windows® Operating System 6.3.9600.16384 False False False False False English (United States)
KERNEL32.dll C:\windows\SYSTEM32\KERNEL32.dll kernel32 kernel32 6.3.9600.17031 (winblue_gdr.140221-1952) Windows NT BASE API Client DLL Microsoft® Windows® Operating System 6.3.9600.17031 False False False False False English (United States)
KERNELBASE.dll C:\windows\SYSTEM32\KERNELBASE.dll Kernelbase.dll Kernelbase.dll.mui 6.3.9600.17031 (winblue_gdr.140221-1952) Windows NT BASE API Client DLL Microsoft® Windows® Operating System 6.3.9600.17031 False False False False False English (United States)
ADVAPI32.dll C:\windows\SYSTEM32\ADVAPI32.dll advapi32.dll advapi32.dll.mui 6.3.9600.16384 (winblue_rtm.130821-1623) Advanced Windows 32 Base API Microsoft® Windows® Operating System 6.3.9600.16384 False False False False False English (United States)
msvcrt.dll C:\windows\SYSTEM32\msvcrt.dll msvcrt.dll msvcrt.dll 7.0.9600.17415 (winblue_r4.141028-1500) Windows NT CRT DLL Microsoft® Windows® Operating System 7.0.9600.17415 False False False False False English (United States)
sechost.dll C:\windows\SYSTEM32\sechost.dll sechost.dll sechost.dll.mui 6.3.9600.16384 (winblue_rtm.130821-1623) Host for SCM/SDDL/LSA Lookup APIs Microsoft® Windows® Operating System 6.3.9600.16384 False False False False False English (United States)
combase.dll C:\windows\SYSTEM32\combase.dll COMBASE.DLL COMBASE.DLL.MUI 6.3.9600.16384 (winblue_rtm.130821-1623) Microsoft COM for Windows Microsoft® Windows® Operating System 6.3.9600.16384 False False False False False English (United States)
USER32.dll C:\windows\SYSTEM32\USER32.dll user32 user32 6.3.9600.16384 (winblue_rtm.130821-1623) Multi-User Windows USER API Client DLL Microsoft® Windows® Operating System 6.3.9600.16384 False False False False False English (United States)
IMM32.DLL C:\windows\system32\IMM32.DLL imm32 imm32 6.3.9600.17415 (winblue_r4.141028-1500) Multi-User Windows IMM32 API Client DLL Microsoft® Windows® Operating System 6.3.9600.17415 False False False False False English (United States)
MSCTF.dll C:\windows\SYSTEM32\MSCTF.dll MSCTF MSCTF.DLL.MUI 6.3.9600.16384 (winblue_rtm.130821-1623) MSCTF Server DLL Microsoft® Windows® Operating System 6.3.9600.16384 False False False False False English (United States)
clr.dll C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll clr.dll clr.dll 4.0.30319.34209 built by: FX452RTMGDR Microsoft .NET Runtime Common Language Runtime - WorkStation Microsoft® .NET Framework 4.0.30319.34209 False False False True False English (United States)
MSVCR120_CLR0400.dll C:\windows\SYSTEM32\MSVCR120_CLR0400.dll msvcr120_clr0400.dll msvcr120_clr0400.dll 12.00.51670.34230 built by: FX452RTMGDR Microsoft® C Runtime Library Microsoft® Visual Studio® 12 CTP 12.00.51670.34230 False False False False False English (United States)
mscorlib.ni.dll C:\windows\assembly\NativeImages_v4.0.30319_32\mscorlib\d1265d6159ea876f9d63ea4c1361b587\mscorlib.ni.dll mscorlib.dll mscorlib.dll 4.0.30319.34209 built by: FX452RTMGDR Microsoft Common Language Runtime Class Library Microsoft® .NET Framework 4.0.30319.34209 False False False True False English (United States)
ole32.dll C:\windows\SYSTEM32\ole32.dll OLE32.DLL OLE32.DLL.MUI 6.3.9600.16384 (winblue_rtm.130821-1623) Microsoft OLE for Windows Microsoft® Windows® Operating System 6.3.9600.16384 False False False False False English (United States)
kernel.appcore.dll C:\windows\SYSTEM32\kernel.appcore.dll kernel.appcore.dll kernel.appcore.dll 6.3.9600.17415 (winblue_r4.141028-1500) AppModel API Host Microsoft® Windows® Operating System 6.3.9600.17415 False False False False False English (United States)
uxtheme.dll C:\windows\system32\uxtheme.dll UxTheme.dll UxTheme.dll.mui 6.3.9600.16384 (winblue_rtm.130821-1623) Microsoft UxTheme Library Microsoft® Windows® Operating System 6.3.9600.16384 False False False False False English (United States)
