Why am I receiving invitations for events I’m no invited to? I view more than one calendar in my google account, but some of them are from other people.
I keep receiving their invites, and the invitations won’t go away no matter if I click accept, decline or maybe
Send me one of the invitations saved as .eml directly at [email protected]. Thank you.
I have the very same problem. Is there a help?
Do you use shared calendars?
Yes I do. How can I set it up?
I am also running into this issue with shared co-worker calendars. Any solution?
sorry for the delayed reply. I have tested it right now and found that Google does not allow you to change the invitation status. We will try to find a workaround but truth is, that it does not work properly in Google calendar either (it displays wrong calendar folder).
I’m having the same issue. Just started using eM Client yesterday. I have 4 invitations showing but none of them are for me. 3 are on my husband’s calendar that he shares with me (view only) and 1 is on a colleague’s calendar that she also shares with me (view only). I’m afraid to hit decline since they’re not really mine. But I want them to go away since they’re not really mine to begin with.
