I would like the read receipts that I send to people not appear under sent folder. I guess this is the normal behaviour for other apps. Haven’t found a setting for this either. Is there one?
Hi Emre, eM client should not be automatically saving read receipts in your sent folder. What version of eM Client are you currently using and what mail service are you using?
Can you please make a screenshot of the issue from your sent folder as well?
Hello Paul,
I’m using gmail as IMAP in eM Client 6.0.21040.0. Here is a screenie.
http://prntscr.com/4wzpoe
Hi Emre, I’ve discussed the issue with the developers and unfortunately it’s the other way around, receipts should be saved into the sent folder, but unfortunately there’s no settings that would disable this option.
I’m currently having issues with my receipts feature, but the setup you’re currently using is the intended behavior.
Sorry for the confusion,
