After updating to RC7 from Beta the initial Mask after stating emClient does not display the input field to write the password. The password can still be entered, but is not displayed.
The problem gets nasty, when emClient is started and the password is not entered directly, but after switching to the prompt. Then the password is impossible to enter and the input field not selectable.
Relevant systeminfo:
Windows 10 Home. Resolution: 4K Language is german.
Hello Maxim,
sorry for the delayed reply, I am having trouble replicating your problem.
Can you please check what your DPI scale in your Windows is? Right click>Display settings and tell me the percentage to ‘Change the size of text, apps and other items’.
Hi Maxim,
thank you for this information, I managed to replicate your issue now. I forwarded it to our developers so it will get fixed soon.
As a work around for now, I suggest either using a smaller DPI (150% for example) and either keep using it for now, or just use it to disable the password protection for now and then go back to 175% DPI setting.
Thank you, Olivia!
I’ll stick to entering the PW blindly and wait for a fix
After all, you got a great application here and this is nothing major.
Best,
Maxim
