Query on exporting the mobile settings to XML between Android and iOS
Is the Mobile app export settings to XML file compatible directly between the Droid and iOS if you use “the same or close version” of the app.
Eg: if I want to Export my eM Client Droid settings to a cloud drive XML file, and then import that same cloud drive XML file to my iPhone eM Client mobile app. Will that work ok.
There is only one format of settings shared between all the platforms, so yes, all the directions should work including exporting settings from mobile to the dedktop.
