I run a Baikal CardDAV/CalDAV Server on my Qnap NAS. I want to reach the server by several Devices like Win PC, Linux PC, Android Phone and so on ,over SSL connection and an DynDNS service.
eM Client doing fine reaching the Server inside my own Network when I use the local IP of the NAS Web sever instead of the DynDNS domain. It doing fine, too if I using the carrier DSL Internet IP. eM Client tells me, there is an unsigned certificate and if I am allow to connect the client gets all the contacts and Calendar entrys. If I use the DynDNS domain instead, the Client don’t finish the setup and don’t ask for permission nothing. My Android Phone with the CardDAV and CalDAV app works fine with the SSL connection and the DynDNS domain. This shows that the server is reachable from outside.
Can you help me to connect my eM Client to my CalDAV server over unsigned SSL?
I send you my log files, but i thing you don’t will see so much in there. If i try to set up the CardDav or CalDav Server with an DynDns Name, eM don’t finish the setup and never shows the Contact or calendar link on the left side. It worksfine with the intern IP or the service carrier extern IP.
