HI,
would it be possible to add “Belgian public holidays” in the calendar ?
I found a lot of contries but Belgium is missing (Luxembourg too)
Thanks in advance for your help
HI,
Tell me, do you think if you’ll add this in a future update ?
Or maybe do you have a link to add manualy ?
Thank’s
You can wait, but who knows when, or if, it will be added.
If you have a Google Calendar, or any of the other free providers like Outlook.com, GMX.com, etc, they all provide holiday calendars.
Or you can subscribe to a Belgian Holidays Calendar (or any other country) from a free subscription site like this one.
Google it. There are many others. Then add your holidays calendar to eMC.
I can’t add “https://www.officeholidays.com/ics/belgium” to the calendar of eMC.
I tried to modify a calendar (Hungary for example) but it’s not possible.
I hope it will be add in a future update
Did you click on that link in your post?
You’ll get a belgium.ics file that you can save and apply to any calendar you want.
Impossible to add manually belgium.ics
I’ll wait for next update of eMC with Belgium public holidays included
This is why I said to add it using your existing calendar provider. If it is already working in their web interface, it will sync with eM Client.
