I purchased the “fix” for the hotmail/live/msn email issues, per the eM Client website announcement and my live email is now working correctly, as is ONE of my msn addresses. The other still continues with the red triangle. I verified the settings match the msn account that IS working, and also that it matches the online instructions. The msn account in question DOES work on our phones, my ipad, and webmail. I have also revoked permission and reset it in that regard.
Is anyone still having this problem after the updated program to fix it?
Thanks!
Is anyone still having this problem after the updated program to fix it? <
Hi.
Ensure AirSync is enabled (under Accounts)
… and that this box is ticked >
PS:
Also, try clicking the Refresh button and see if it will send any mail stuck in the Outbox.
If it does you can use it as a workaround…and ignore the red triangle for now.
Thank you! Yes, that box is ticked and AirSync is also ticked.
And I have refreshed multiple times.
Hi Bee.
Other than removing the problem account and setting it up again, I’m out of ideas on this one. Perhaps Gary etc could advise you further.
Also, as you may know, if you’re Pro License is within 1 year of purchase you can use the EMC tech support service, or extend it if required…
Support | Remote Assistance | License Manager | eM Client
