I’m using emClient calendar with Synology calender package. I have big problems with reccuring events with reminders. After a while, there are tousendas of reminders at one event. I tried to get the calender via CALDAV (GET command) and there are at several events a lot of VALARM entries.
The biggest issue with CalDAV is that the same url has different results in each application. What works with Thunderbird Lightning, does not work with eM Client, and what works with Android, doesn’t work with desktop clients. And they all have different methods of syncing that data.
What I would suggest is that if you have a Pro License, you open a support ticket directly with eM Client. When I had issues with CalDAV, they got together with my provider and found a solution.
Just did some tests:
2 emClients at one calendar. Single event with reminder.
Confirming reminder on first computer -> all ok
Afterwards confirming on second computer->new reminder added (available in web interface of Synology, also visible in debug file of emclient.)
Debug of confirming on 2nd computer:
14:42:12.325|001| Synchronizer.Modify: nextReminder componentDtStamp
14:42:12.337|01A| C: PutCommand https://192.168.55.65:20003/caldav.php/calendar/cqgset/73501528-4082-4250-82e9-016d69995b8d.ics
14:42:12.337|01A| H: User-Agent: eM Client/7.2.36694.0
14:42:12.337|01A| H: Accept-Encoding: gzip, deflate
14:42:12.337|01A| BEGIN:VCALENDAR
14:42:12.337|01A| VERSION:2.0
14:42:12.337|01A| PRODID:-//MailClient.VObject/7.2.36694.0
14:42:12.337|01A| BEGIN:VTIMEZONE
14:42:12.337|01A| TZID:W. Europe Standard Time
14:42:12.337|01A| X-EM-DISPLAYNAME:(UTC+01:00) Amsterdam\, Berlin\, Bern\, Rom\, Stockholm\,
14:42:12.337|01A| Wien
14:42:12.337|01A| BEGIN:STANDARD
14:42:12.337|01A| TZNAME:Mitteleurop??ische Zeit
14:42:12.337|01A| DTSTART:00010101T030000
14:42:12.337|01A| TZOFFSETFROM:+0200
14:42:12.337|01A| TZOFFSETTO:+0100
14:42:12.337|01A| RRULE:FREQ=YEARLY;BYDAY=-1SU;BYMONTH=10
14:42:12.337|01A| END:STANDARD
14:42:12.337|01A| BEGIN:DAYLIGHT
14:42:12.337|01A| TZNAME:Mitteleurop??ische Sommerzeit
14:42:12.337|01A| DTSTART:00010101T020000
14:42:12.337|01A| TZOFFSETFROM:+0100
14:42:12.337|01A| TZOFFSETTO:+0200
14:42:12.337|01A| RRULE:FREQ=YEARLY;BYDAY=-1SU;BYMONTH=3
14:42:12.337|01A| END:DAYLIGHT
14:42:12.337|01A| END:VTIMEZONE
14:42:12.337|01A| BEGIN:VEVENT
14:42:12.337|01A| UID:73501528-4082-4250-82e9-016d69995b8d
14:42:12.337|01A| DTSTART;TZID=W. Europe Standard Time:20191004T145200
14:42:12.337|01A| DTEND;TZID=W. Europe Standard Time:20191004T152200
14:42:12.337|01A| TRANSP:OPAQUE
14:42:12.337|01A| X-MICROSOFT-CDO-BUSYSTATUS:BUSY
14:42:12.337|01A| LAST-MODIFIED:20191004T124212Z
14:42:12.337|01A| DTSTAMP:20191004T124212Z
14:42:12.337|01A| CREATED:20191004T123825Z
14:42:12.337|01A| SUMMARY:tttteeee
14:42:12.337|01A| CLASS:PUBLIC
14:42:12.338|01A| BEGIN:VALARM
14:42:12.338|01A| ACTION:DISPLAY
14:42:12.338|01A| DESCRIPTION:Alarm
14:42:12.338|01A| X-MOZ-LASTACK:99991231T235859Z
14:42:12.338|01A| ACKNOWLEDGED:99991231T235859Z
14:42:12.338|01A| TRIGGER;RELATED=START:-PT10M
14:42:12.338|01A| X-WR-ALARMUID:e5a94d51-6e66-4466-a409-d373edd10c2b
14:42:12.338|01A| END:VALARM
14:42:12.338|01A| X-MOZ-LASTACK:20191004T124100Z
14:42:12.338|01A| ACKNOWLEDGED:20191004T124100Z
14:42:12.338|01A| END:VEVENT
14:42:12.338|01A| END:VCALENDAR
14:42:12.338|01A|
14:42:12.574|01A| S: PUT https://192.168.55.65:20003/caldav.php/calendar/cqgset/73501528-4082-4250-82e9-016d69995b8d.ics
14:42:12.574|01A| PreconditionFailed Precondition Failed
14:42:12.574|01A| H: Connection: keep-alive
14:42:12.574|01A| H: Keep-Alive: timeout=20
14:42:12.574|01A| H: DAV: 1, 2, 3, access-control, calendar-access, calendar-schedule,extended-mkcol, bind, addressbook, calendar-auto-schedule
14:42:12.574|01A| H: X-DAViCal-Version: DAViCal/1.1.7; DB/1.2.12
14:42:12.574|01A| H: Content-Length: 193
14:42:12.574|01A| H: Content-Type: text/xml; charset="utf-8"
14:42:12.574|01A| H: Date: Fri, 04 Oct 2019 12:42:12 GMT
14:42:12.574|01A| H: Server: nginx
14:42:12.575|01A| Response, stream length:
193, 193
14:42:12.575|01A| Content:
<?xml version="1.0" encoding="utf-8" ?>
<error xmlns="DAV:"><br alt="" name="" rel="" target="" title="" type="" value=""> <if-match></if-match>Existing resource ETag of "b298be9dbfacf4b04214400f380f6ce5" does not match "0d35d4d8323160fce1cc371cf18e49fb"<br alt="" name="" rel="" target="" title="" type="" value=""></error>
14:42:12.580|01A| C: GetCommand https://192.168.55.65:20003/caldav.php/calendar/cqgset/73501528-4082-4250-82e9-016d69995b8d.ics
14:42:12.580|01A| H: User-Agent: eM Client/7.2.36694.0
14:42:12.580|01A| H: Accept-Encoding: gzip, deflate
14:42:12.798|01A| S: GET https://192.168.55.65:20003/caldav.php/calendar/cqgset/73501528-4082-4250-82e9-016d69995b8d.ics
14:42:12.798|01A| OK OK
14:42:12.798|01A| H: Connection: keep-alive
14:42:12.798|01A| H: Keep-Alive: timeout=20
14:42:12.798|01A| H: DAV: 1, 2, 3, access-control, calendar-access, calendar-schedule,extended-mkcol, bind, addressbook, calendar-auto-schedule
14:42:12.798|01A| H: X-DAViCal-Version: DAViCal/1.1.7; DB/1.2.12
14:42:12.798|01A| H: Content-Length: 1320
14:42:12.798|01A| H: Content-Type: text/calendar; component=vevent; charset="utf-8"
14:42:12.798|01A| H: Date: Fri, 04 Oct 2019 12:42:12 GMT
14:42:12.798|01A| H: ETag: "b298be9dbfacf4b04214400f380f6ce5"
14:42:12.798|01A| H: Server: nginx
14:42:12.798|01A| Response, stream length:
1320, 1320
14:42:12.798|01A| Content:
BEGIN:VCALENDAR
14:42:12.798|01A| VERSION:2.0
14:42:12.798|01A| PRODID:-//MailClient.VObject/7.2.35576.0
14:42:12.798|01A| BEGIN:VTIMEZONE
14:42:12.799|01A| TZID:W. Europe Standard Time
14:42:12.799|01A| X-EM-DISPLAYNAME:(UTC+01:00) Amsterdam\, Berlin\, Bern\, Rom\, Stockholm\,
14:42:12.799|01A| Wien
14:42:12.799|01A| BEGIN:STANDARD
14:42:12.799|01A| TZNAME:Mitteleurop??ische Zeit
14:42:12.799|01A| DTSTART:00010101T030000
14:42:12.799|01A| TZOFFSETFROM:+0200
14:42:12.799|01A| TZOFFSETTO:+0100
14:42:12.799|01A| RRULE:FREQ=YEARLY;BYDAY=-1SU;BYMONTH=10
14:42:12.799|01A| END:STANDARD
14:42:12.799|01A| BEGIN:DAYLIGHT
14:42:12.799|01A| TZNAME:Mitteleurop??ische Sommerzeit
14:42:12.799|01A| DTSTART:00010101T020000
14:42:12.799|01A| TZOFFSETFROM:+0100
14:42:12.799|01A| TZOFFSETTO:+0200
14:42:12.799|01A| RRULE:FREQ=YEARLY;BYDAY=-1SU;BYMONTH=3
14:42:12.799|01A| END:DAYLIGHT
14:42:12.799|01A| END:VTIMEZONE
14:42:12.799|01A| BEGIN:VEVENT
14:42:12.799|01A| UID:73501528-4082-4250-82e9-016d69995b8d
14:42:12.799|01A| DTSTART;TZID=W. Europe Standard Time:20191004T145200
14:42:12.799|01A| DTEND;TZID=W. Europe Standard Time:20191004T152200
14:42:12.799|01A| TRANSP:OPAQUE
14:42:12.799|01A| X-MICROSOFT-CDO-BUSYSTATUS:BUSY
14:42:12.799|01A| LAST-MODIFIED:20191004T124205Z
14:42:12.799|01A| DTSTAMP:20191004T124205Z
14:42:12.799|01A| CREATED:20191004T123825Z
14:42:12.799|01A| SUMMARY:tttteeee
14:42:12.799|01A| CLASS:PUBLIC
14:42:12.799|01A| BEGIN:VALARM
14:42:12.799|01A| ACTION:DISPLAY
14:42:12.799|01A| DESCRIPTION:Alarm
14:42:12.799|01A| X-MOZ-LASTACK:99991231T235859Z
14:42:12.799|01A| ACKNOWLEDGED:99991231T235859Z
14:42:12.799|01A| TRIGGER;RELATED=START:-PT10M
14:42:12.799|01A| X-WR-ALARMUID:d107668a-3f6b-4020-9c6b-272b06b8db26
14:42:12.799|01A| END:VALARM
14:42:12.799|01A| END:VEVENT
14:42:12.799|01A| END:VCALENDAR
14:42:12.799|01A|
14:42:12.812|01A| C: PutCommand https://192.168.55.65:20003/caldav.php/calendar/cqgset/73501528-4082-4250-82e9-016d69995b8d.ics
14:42:12.812|01A| H: User-Agent: eM Client/7.2.36694.0
14:42:12.812|01A| H: Accept-Encoding: gzip, deflate
14:42:12.812|01A| BEGIN:VCALENDAR
14:42:12.812|01A| VERSION:2.0
14:42:12.812|01A| PRODID:-//MailClient.VObject/7.2.36694.0
14:42:12.812|01A| BEGIN:VTIMEZONE
14:42:12.812|01A| TZID:W. Europe Standard Time
14:42:12.812|01A| X-EM-DISPLAYNAME:(UTC+01:00) Amsterdam\, Berlin\, Bern\, Rom\, Stockholm\,
14:42:12.812|01A| Wien
14:42:12.812|01A| BEGIN:STANDARD
14:42:12.813|01A| TZNAME:Mitteleurop??ische Zeit
14:42:12.813|01A| DTSTART:00010101T030000
14:42:12.813|01A| TZOFFSETFROM:+0200
14:42:12.813|01A| TZOFFSETTO:+0100
14:42:12.813|01A| RRULE:FREQ=YEARLY;BYDAY=-1SU;BYMONTH=10
14:42:12.813|01A| END:STANDARD
14:42:12.813|01A| BEGIN:DAYLIGHT
14:42:12.813|01A| TZNAME:Mitteleurop??ische Sommerzeit
14:42:12.813|01A| DTSTART:00010101T020000
14:42:12.813|01A| TZOFFSETFROM:+0100
14:42:12.813|01A| TZOFFSETTO:+0200
14:42:12.813|01A| RRULE:FREQ=YEARLY;BYDAY=-1SU;BYMONTH=3
14:42:12.813|01A| END:DAYLIGHT
14:42:12.813|01A| END:VTIMEZONE
14:42:12.813|01A| BEGIN:VEVENT
14:42:12.813|01A| UID:73501528-4082-4250-82e9-016d69995b8d
14:42:12.813|01A| DTSTART;TZID=W. Europe Standard Time:20191004T145200
14:42:12.813|01A| DTEND;TZID=W. Europe Standard Time:20191004T152200
14:42:12.813|01A| TRANSP:OPAQUE
14:42:12.813|01A| X-MICROSOFT-CDO-BUSYSTATUS:BUSY
14:42:12.813|01A| LAST-MODIFIED:20191004T124212Z
14:42:12.813|01A| DTSTAMP:20191004T124212Z
14:42:12.813|01A| CREATED:20191004T123825Z
14:42:12.813|01A| SUMMARY:tttteeee
14:42:12.813|01A| CLASS:PUBLIC
14:42:12.813|01A| BEGIN:VALARM
14:42:12.813|01A| ACTION:DISPLAY
14:42:12.813|01A| DESCRIPTION:Alarm
14:42:12.813|01A| X-MOZ-LASTACK:99991231T235859Z
14:42:12.813|01A| ACKNOWLEDGED:99991231T235859Z
14:42:12.813|01A| TRIGGER;RELATED=START:-PT10M
14:42:12.813|01A| X-WR-ALARMUID:d107668a-3f6b-4020-9c6b-272b06b8db26
14:42:12.813|01A| END:VALARM
14:42:12.813|01A| END:VEVENT
14:42:12.813|01A| END:VCALENDAR
14:42:12.813|01A|
14:42:13.074|01A| S: PUT https://192.168.55.65:20003/caldav.php/calendar/cqgset/73501528-4082-4250-82e9-016d69995b8d.ics
14:42:13.074|01A| NoContent No Content
14:42:13.074|01A| H: Connection: keep-alive
14:42:13.074|01A| H: Keep-Alive: timeout=20
14:42:13.074|01A| H: DAV: 1, 2, 3, access-control, calendar-access, calendar-schedule,extended-mkcol, bind, addressbook, calendar-auto-schedule
14:42:13.074|01A| H: X-DAViCal-Version: DAViCal/1.1.7; DB/1.2.12
14:42:13.074|01A| H: Content-Type: text/plain; charset="utf-8"
14:42:13.075|01A| H: Date: Fri, 04 Oct 2019 12:42:13 GMT
14:42:13.075|01A| H: ETag: "3996a6c024f7250a42b64088b8fc0852"
14:42:13.075|01A| H: Server: nginx
14:42:20.964|01A| SynchronizeItemsCommand executing on ( /c6c107f6-00a9-4ad0-87f1-1acb6662d027/0/cqgset)
14:42:20.965|01A| C: SyncCollectionCommand https://192.168.55.65:20003/caldav.php/calendar/cqgset/
14:42:20.965|01A| H: User-Agent: eM Client/7.2.36694.0
14:42:20.965|01A| H: Accept-Encoding: gzip, deflate
14:42:20.965|01A|<?xml version="1.0" encoding="utf-8"?><sync-collection xmlns:d="DAV:"><sync-token>data:,649</sync-token><prop><getetag></getetag><getcontenttype></getcontenttype></prop></sync-collection>
14:42:21.203|01A| S: REPORT https://192.168.55.65:20003/caldav.php/calendar/cqgset/
14:42:21.203|01A| 207 Multi-Status
14:42:21.203|01A| H: Connection: keep-alive
14:42:21.203|01A| H: Keep-Alive: timeout=20
14:42:21.203|01A| H: DAV: 1, 2, 3, access-control, calendar-access, calendar-schedule,extended-mkcol, bind, addressbook, calendar-auto-schedule
14:42:21.203|01A| H: X-DAViCal-Version: DAViCal/1.1.7; DB/1.2.12
14:42:21.203|01A| H: Content-Length: 438
14:42:21.203|01A| H: Content-Type: text/xml; charset="utf-8"
14:42:21.203|01A| H: Date: Fri, 04 Oct 2019 12:42:21 GMT
14:42:21.203|01A| H: ETag: "2c86f8c31deba1bc668cddb74866a760"
14:42:21.203|01A| H: Server: nginx
14:42:21.203|01A| Response, stream length:
438, 438
14:42:21.203|01A| Content:
<multistatus xmlns="DAV:"><br alt="" name="" rel="" target="" title="" type="" value=""> <response><br alt="" name="" rel="" target="" title="" type="" value=""> <href>/caldav.php/calendar/cqgset/73501528-4082-4250-82e9-016d69995b8d.ics</href><br alt="" name="" rel="" target="" title="" type="" value=""> <propstat><br alt="" name="" rel="" target="" title="" type="" value="">
<prop><br alt="" name="" rel="" target="" title="" type="" value="">
<getetag>"3996a6c024f7250a42b64088b8fc0852"</getetag><br alt="" name="" rel="" target="" title="" type="" value="">
<getcontenttype>text/calendar; component=vevent</getcontenttype><br alt="" name="" rel="" target="" title="" type="" value="">
</prop><br alt="" name="" rel="" target="" title="" type="" value="">
<status>HTTP/1.1 200 OK</status><br alt="" name="" rel="" target="" title="" type="" value=""> </propstat><br alt="" name="" rel="" target="" title="" type="" value=""> </response><br alt="" name="" rel="" target="" title="" type="" value=""> <sync-token>data:,650</sync-token><br alt="" name="" rel="" target="" title="" type="" value=""></multistatus>
14:42:21.206|01A| SynchronizeItemsCommand finished on ( /c6c107f6-00a9-4ad0-87f1-1acb6662d027/0/cqgset)
14:42:21.206|01A| SynchronizeItemsCommand executing on ( /c6c107f6-00a9-4ad0-87f1-1acb6662d027/0/vtkrrm)
14:42:21.206|01A| C: SyncCollectionCommand https://192.168.55.65:20003/caldav.php/calendar/vtkrrm/
14:42:21.206|01A| H: User-Agent: eM Client/7.2.36694.0
14:42:21.206|01A| H: Accept-Encoding: gzip, deflate
14:42:21.206|01A|<?xml version="1.0" encoding="utf-8"?><sync-collection xmlns:d="DAV:"><sync-token>data:,615</sync-token><prop><getetag></getetag><getcontenttype></getcontenttype></prop></sync-collection>
14:42:21.430|01A| S: REPORT https://192.168.55.65:20003/caldav.php/calendar/vtkrrm/
14:42:21.430|01A| 207 Multi-Status
14:42:21.430|01A| H: Connection: keep-alive
14:42:21.430|01A| H: Keep-Alive: timeout=20
14:42:21.430|01A| H: DAV: 1, 2, 3, access-control, calendar-access, calendar-schedule,extended-mkcol, bind, addressbook, calendar-auto-schedule
14:42:21.430|01A| H: X-DAViCal-Version: DAViCal/1.1.7; DB/1.2.12
14:42:21.430|01A| H: Content-Length: 118
14:42:21.430|01A| H: Content-Type: text/xml; charset="utf-8"
14:42:21.430|01A| H: Date: Fri, 04 Oct 2019 12:42:21 GMT
14:42:21.430|01A| H: ETag: "8778e2adbfa63a218f8d70b04b470577"
14:42:21.430|01A| H: Server: nginx
14:42:21.430|01A| Response, stream length:
118, 118
14:42:21.430|01A| Content:
<multistatus xmlns="DAV:"><br alt="" name="" rel="" target="" title="" type="" value=""> <sync-token>data:,615</sync-token><br alt="" name="" rel="" target="" title="" type="" value=""></multistatus>
14:42:21.431|01A| SynchronizeItemsCommand finished on ( /c6c107f6-00a9-4ad0-87f1-1acb6662d027/0/vtkrrm)
14:42:21.431|01A| SynchronizeItemsCommand executing on ( /c6c107f6-00a9-4ad0-87f1-1acb6662d027/0/2cc2d93a-1dc2-4d31-949a-9395e63d5b77)
14:42:21.431|01A| C: SyncCollectionCommand https://192.168.55.65:20003/caldav.php/calendar/2cc2d93a-1dc2-4d31-949a-9395e63d5b77/
14:42:21.431|01A| H: User-Agent: eM Client/7.2.36694.0
14:42:21.431|01A| H: Accept-Encoding: gzip, deflate
14:42:21.432|01A|<?xml version="1.0" encoding="utf-8"?><sync-collection xmlns:d="DAV:"><sync-token>data:,617</sync-token><prop><getetag></getetag><getcontenttype></getcontenttype></prop></sync-collection>
14:42:21.669|01A| S: REPORT https://192.168.55.65:20003/caldav.php/calendar/2cc2d93a-1dc2-4d31-949a-9395e63d5b77/
14:42:21.669|01A| 207 Multi-Status
14:42:21.669|01A| H: Connection: keep-alive
14:42:21.669|01A| H: Keep-Alive: timeout=20
14:42:21.669|01A| H: DAV: 1, 2, 3, access-control, calendar-access, calendar-schedule,extended-mkcol, bind, addressbook, calendar-auto-schedule
14:42:21.669|01A| H: X-DAViCal-Version: DAViCal/1.1.7; DB/1.2.12
14:42:21.669|01A| H: Content-Length: 118
14:42:21.669|01A| H: Content-Type: text/xml; charset="utf-8"
14:42:21.669|01A| H: Date: Fri, 04 Oct 2019 12:42:21 GMT
14:42:21.669|01A| H: ETag: "5a9cee8a78d81b6c6d793e5316571960"
14:42:21.669|01A| H: Server: nginx
14:42:21.669|01A| Response, stream length:
118, 118
14:42:21.669|01A| Content:
<multistatus xmlns="DAV:"><br alt="" name="" rel="" target="" title="" type="" value=""> <sync-token>data:,617</sync-token><br alt="" name="" rel="" target="" title="" type="" value=""></multistatus>
14:42:21.670|01A| SynchronizeItemsCommand finished on ( /c6c107f6-00a9-4ad0-87f1-1acb6662d027/0/2cc2d93a-1dc2-4d31-949a-9395e63d5b77)
14:42:21.671|01A| SynchronizeItemsCommand executing on ( /c6c107f6-00a9-4ad0-87f1-1acb6662d027/0/home)
14:42:21.671|01A| C: SyncCollectionCommand https://192.168.55.65:20003/caldav.php/calendar/home/
14:42:21.671|01A| H: User-Agent: eM Client/7.2.36694.0
14:42:21.671|01A| H: Accept-Encoding: gzip, deflate
14:42:21.671|01A|<?xml version="1.0" encoding="utf-8"?><sync-collection xmlns:d="DAV:"><sync-token>data:,9</sync-token><prop><getetag></getetag><getcontenttype></getcontenttype></prop></sync-collection>
14:42:21.908|01A| S: REPORT https://192.168.55.65:20003/caldav.php/calendar/home/
14:42:21.908|01A| 207 Multi-Status
14:42:21.908|01A| H: Connection: keep-alive
14:42:21.908|01A| H: Keep-Alive: timeout=20
14:42:21.908|01A| H: DAV: 1, 2, 3, access-control, calendar-access, calendar-schedule,extended-mkcol, bind, addressbook, calendar-auto-schedule
14:42:21.908|01A| H: X-DAViCal-Version: DAViCal/1.1.7; DB/1.2.12
14:42:21.908|01A| H: Content-Length: 116
14:42:21.908|01A| H: Content-Type: text/xml; charset="utf-8"
14:42:21.908|01A| H: Date: Fri, 04 Oct 2019 12:42:22 GMT
14:42:21.908|01A| H: ETag: "d5d385bfb2228f4e80f25a9c038eaadc"
14:42:21.908|01A| H: Server: nginx
14:42:21.908|01A| Response, stream length:
116, 116
14:42:21.908|01A| Content:
<multistatus xmlns="DAV:"><br alt="" name="" rel="" target="" title="" type="" value=""> <sync-token>data:,9</sync-token><br alt="" name="" rel="" target="" title="" type="" value=""></multistatus>
14:42:21.909|01A| SynchronizeItemsCommand finished on ( /c6c107f6-00a9-4ad0-87f1-1acb6662d027/0/home)
14:42:21.909|01A| SynchronizeItemsCommand executing on ( /c6c107f6-00a9-4ad0-87f1-1acb6662d027/0/home\_todo)
14:42:21.909|01A| C: SyncCollectionCommand https://192.168.55.65:20003/caldav.php/calendar/home\_todo/
14:42:21.909|01A| H: User-Agent: eM Client/7.2.36694.0
14:42:21.910|01A| H: Accept-Encoding: gzip, deflate
14:42:21.910|01A|<?xml version="1.0" encoding="utf-8"?><sync-collection xmlns:d="DAV:"><sync-token>data:,581</sync-token><prop><getetag></getetag><getcontenttype></getcontenttype></prop></sync-collection>
14:42:22.132|01A| S: REPORT https://192.168.55.65:20003/caldav.php/calendar/home\_todo/
14:42:22.132|01A| 207 Multi-Status
14:42:22.132|01A| H: Connection: keep-alive
14:42:22.132|01A| H: Keep-Alive: timeout=20
14:42:22.132|01A| H: DAV: 1, 2, 3, access-control, calendar-access, calendar-schedule,extended-mkcol, bind, addressbook, calendar-auto-schedule
14:42:22.132|01A| H: X-DAViCal-Version: DAViCal/1.1.7; DB/1.2.12
14:42:22.132|01A| H: Content-Length: 118
14:42:22.132|01A| H: Content-Type: text/xml; charset="utf-8"
14:42:22.132|01A| H: Date: Fri, 04 Oct 2019 12:42:22 GMT
14:42:22.132|01A| H: ETag: "a38587f48a4e5f3388d01d809a868a05"
14:42:22.132|01A| H: Server: nginx
14:42:22.132|01A| Response, stream length:
118, 118
14:42:22.132|01A| Content:
<multistatus xmlns="DAV:"><br alt="" name="" rel="" target="" title="" type="" value=""> <sync-token>data:,581</sync-token><br alt="" name="" rel="" target="" title="" type="" value=""></multistatus>
14:42:22.132|01A| SynchronizeItemsCommand finished on ( /c6c107f6-00a9-4ad0-87f1-1acb6662d027/0/home\_todo)
14:42:22.132|01A| SynchronizeItemsCommand executing on ( /c6c107f6-00a9-4ad0-87f1-1acb6662d027/inbox)
14:42:22.133|01A| C: PropfindCommand https://192.168.55.65:20003/caldav.php/calendar/.in/
14:42:22.133|01A| H: User-Agent: eM Client/7.2.36694.0
14:42:22.133|01A| H: Accept-Encoding: gzip, deflate
14:42:22.133|01A|<?xml version="1.0" encoding="utf-8"?><propfind xmlns:d="DAV:"><prop><getetag></getetag><getcontenttype></getcontenttype></prop></propfind>
14:42:22.353|01A| S: PROPFIND https://192.168.55.65:20003/caldav.php/calendar/.in/
14:42:22.353|01A| 207 Multi-Status
14:42:22.353|01A| H: Connection: keep-alive
14:42:22.354|01A| H: Keep-Alive: timeout=20
14:42:22.354|01A| H: DAV: 1, 2, 3, access-control, calendar-access, calendar-schedule,extended-mkcol, bind, addressbook, calendar-auto-schedule
14:42:22.354|01A| H: X-DAViCal-Version: DAViCal/1.1.7; DB/1.2.12
14:42:22.354|01A| H: Content-Length: 290
14:42:22.354|01A| H: Content-Type: text/xml; charset="utf-8"
14:42:22.354|01A| H: Date: Fri, 04 Oct 2019 12:42:22 GMT
14:42:22.354|01A| H: ETag: "eca428c61870a615db20b89fc2dd711a"
14:42:22.354|01A| H: Server: nginx
14:42:22.354|01A| Response, stream length:
290, 290
14:42:22.354|01A| Content:
<multistatus xmlns="DAV:"><br alt="" name="" rel="" target="" title="" type="" value=""> <response><br alt="" name="" rel="" target="" title="" type="" value=""> <href>/caldav.php/calendar/.in/</href><br alt="" name="" rel="" target="" title="" type="" value=""> <propstat><br alt="" name="" rel="" target="" title="" type="" value="">
<getcontenttype>httpd/unix-directory</getcontenttype><br alt="" name="" rel="" target="" title="" type="" value="">
<status>HTTP/1.1 200 OK</status><br alt="" name="" rel="" target="" title="" type="" value=""> </propstat><br alt="" name="" rel="" target="" title="" type="" value=""> </response><br alt="" name="" rel="" target="" title="" type="" value=""></multistatus>
14:42:22.355|01A| SynchronizeItemsCommand finished on ( /c6c107f6-00a9-4ad0-87f1-1acb6662d027/inbox)
So emClient seems to be the problem. Confirming on more than one computer/device adds a new alarm block. Right?
So after a while, with several instances of emclient the events “explode”
Thanks for help,
Christian
If you have a Pro License, please open a support ticket directly with eM Client as I don’t think anyone on this community forum will/can comment on your log data.
In the mean-time maybe try uninstall eM Client and then download and install 7.2.35595 from the Release History. See if there is any difference with that version.
