I’m trying to transition my wife from Thunderbird to Em Client in the hopes she can use it as her new local email client.
I’ve searched for a solution for this issue but have had no luck.
I installed Em Client on the new PC and copied over the Thunderbird data files from Appdata (.msf and corresponding files with no extension)
When I try to import from within Em Client, it detects the lack of Thunderbird software (which is expected) and suggests doing an import of the existing Thunderbird data files. But when I continue and select either import account or local folders and point it towards said transferred data files, I am unable to proceed as it never shows any of the data files to import.
On the Select folders to import screen, all I see is a blank window.
Any ideas what I can do to have eM Client see and be able to import these data files?
Thanks!
